Ga door naar hoofdinhoud
Canon EOS 6D Analog Screen Replacement
Wat je nodig hebt
  1. Canon EOS 6D Analog Screen Replacement, Rear Body Panel: stap 1, afbeelding 1 van 1
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon EOS 6D Analog Screen Replacement: stap 2, afbeelding 1 van 1
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon EOS 6D Analog Screen Replacement: stap 3, afbeelding 1 van 1
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
    Vraag FixBot
    Voeg opmerking toe
  4. Canon EOS 6D Analog Screen Replacement: stap 4, afbeelding 1 van 1
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  5. Canon EOS 6D Analog Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon EOS 6D Analog Screen Replacement: stap 6, afbeelding 1 van 1
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  7. Canon EOS 6D Analog Screen Replacement: stap 7, afbeelding 1 van 1
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  8. Canon EOS 6D Analog Screen Replacement: stap 8, afbeelding 1 van 2 Canon EOS 6D Analog Screen Replacement: stap 8, afbeelding 2 van 2
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
    Vraag FixBot
    Voeg opmerking toe
  9. Canon EOS 6D Analog Screen Replacement, Front and Top Body Panels: stap 9, afbeelding 1 van 1
    • Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
    Vraag FixBot
    Voeg opmerking toe
  10. Canon EOS 6D Analog Screen Replacement: stap 10, afbeelding 1 van 1
    • Rotate the camera so the side with the SD card slot is facing you.
    • Remove the 4mm Phillips #00 screw from the bottom edge of this side.
    Vraag FixBot
    Voeg opmerking toe
  11. Canon EOS 6D Analog Screen Replacement: stap 11, afbeelding 1 van 1
    • Rotate the camera so the bottom is facing you.
    • Two 8mm Phillips #00
    • One 4mm Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  12. Canon EOS 6D Analog Screen Replacement: stap 12, afbeelding 1 van 1
    • Remove the bottom panel from the camera by using your fingers to pull outward on the tab inside the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  13. Canon EOS 6D Analog Screen Replacement: stap 13, afbeelding 1 van 1
    • Rotate the camera so the front is facing you.
    • Three 5mm Phillips #00
    • Two 6mm Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  14. Canon EOS 6D Analog Screen Replacement: stap 14, afbeelding 1 van 1
    • One 4mm fine-thread Phillips #00
    • Two 4mm coarse-thread Phillips #00
    Vraag FixBot
    Voeg opmerking toe
  15. Canon EOS 6D Analog Screen Replacement: stap 15, afbeelding 1 van 1
    • The red speaker wire is attached to the inside of the front panel. Opening the front panel forcefully may break it.
    • Slowly fold the front panel to the right without pulling it away from the right edge of the camera.
    Vraag FixBot
    Voeg opmerking toe
  16. Canon EOS 6D Analog Screen Replacement: stap 16, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw on the inside of the front panel to separate the panel from the speaker wire.
    Vraag FixBot
    Voeg opmerking toe
  17. Canon EOS 6D Analog Screen Replacement: stap 17, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the strap hook.
    Vraag FixBot
    Voeg opmerking toe
  18. Canon EOS 6D Analog Screen Replacement: stap 18, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the shutter button.
    Vraag FixBot
    Voeg opmerking toe
  19. Canon EOS 6D Analog Screen Replacement: stap 19, afbeelding 1 van 1
    • Rotate the camera so the top is facing you.
    • Remove the 6mm Phillips #00 screw from next to the analog screen.
    Vraag FixBot
    Voeg opmerking toe
  20. Canon EOS 6D Analog Screen Replacement: stap 20, afbeelding 1 van 1
    • Rotate the camera so the back is facing you.
    • Remove the Phillips #00 screw from the viewfinder focus.
    Vraag FixBot
    Voeg opmerking toe
  21. Canon EOS 6D Analog Screen Replacement: stap 21, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully detach the two light brown ribbon wires on the top panel:
    • The right ribbon by prying it out with the flat end of the spudger.
    • The left ribbon by using tweezers to gently wiggle it out toward the top.
    Vraag FixBot
    Voeg opmerking toe
  22. Canon EOS 6D Analog Screen Replacement: stap 22, afbeelding 1 van 1
    • A ribbon wire connects the inside of the top panel to the body of the camera.
    • Slowly lift the top panel to about an inch above the body of the camera.
    • Carefully use the flat end of the spudger to detach the ribbon wire from the top of the camera.
    Vraag FixBot
    Voeg opmerking toe
  23. Canon EOS 6D Analog Screen Replacement: stap 23, afbeelding 1 van 1
    • Grip the remaining side panel with your fingers and gently pop it off the camera.
    Vraag FixBot
    Voeg opmerking toe
  24. Canon EOS 6D Analog Screen Replacement, Analog Screen: stap 24, afbeelding 1 van 1
    • Use the pointed end of the spudger to flip up two silver ribbon wire latches on the inside of the top panel.
    Vraag FixBot
    Voeg opmerking toe
  25. Canon EOS 6D Analog Screen Replacement: stap 25, afbeelding 1 van 1
    • Use the pointed end of the spudger to slide out the two light brown ribbon wires.
    Vraag FixBot
    Voeg opmerking toe
  26. Canon EOS 6D Analog Screen Replacement: stap 26, afbeelding 1 van 1
    • Use the pointed end of the spudger to carefully remove the third light brown ribbon wire.
    Vraag FixBot
    Voeg opmerking toe
  27. Canon EOS 6D Analog Screen Replacement: stap 27, afbeelding 1 van 1
    • Remove four 5mm Phillips #00 screws from the inside of the top panel.
    Vraag FixBot
    Voeg opmerking toe
  28. Canon EOS 6D Analog Screen Replacement: stap 28, afbeelding 1 van 2 Canon EOS 6D Analog Screen Replacement: stap 28, afbeelding 2 van 2
    • Carefully slide the flat end of the spudger underneath the screen and lift it out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Justin Thomas
2.233 Reputatie
6 handleidingen geschreven
Cal Poly, Team 11-48, Amido Spring 2014 Lid van Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
4 Leden
20 handleidingen geschreven
2Gids Commentaar
any way to replace the sd card side panel without having to take the lcd panel off
Nate Kennedy - Antwoord Deel
Thank you Justin! Very well done. Fixed the camera for $40 rather than replacing it for 1000+
Matt Ryan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 81
Altijd: 8,280
