Ga door naar hoofdinhoud
Boosted Board 1st Generation Remote Battery Replacement
Wat je nodig hebt
  1. Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: stap 1, afbeelding 1 van 3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: stap 1, afbeelding 2 van 3 Boosted Board 1st Generation Remote Battery Replacement, Remote Battery: stap 1, afbeelding 3 van 3
    • Before disassembling your remote, be sure it is powered off.
    • Remove the four 17.57mm screws from the bottom of the case with a PH0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Boosted Board 1st Generation Remote Battery Replacement: stap 2, afbeelding 1 van 2 Boosted Board 1st Generation Remote Battery Replacement: stap 2, afbeelding 2 van 2
    • Carefully separate the two halves of the casing by pulling them apart at the seam.
    • Be sure to keep the scroll wheel, lever and buttons attached to the housing.
    Vraag FixBot
    Voeg opmerking toe
  3. Boosted Board 1st Generation Remote Battery Replacement: stap 3, afbeelding 1 van 3 Boosted Board 1st Generation Remote Battery Replacement: stap 3, afbeelding 2 van 3 Boosted Board 1st Generation Remote Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the rectangular black adhesive foam on top of the battery by peeling it away from the battery.
    • Desolder the battery connections from the circuit board.
    • Replace the dead battery with a new 3.7 volt lithium polymer battery.
    • Refer here for more information how to desolder the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kevin Manko
164 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-7, Livingston Fall 2016 Lid van Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Leden
6 handleidingen geschreven
4Gids Commentaar
Where can I get the battery? Or can you give specs? Thanks!
Dan Davie - Antwoord Deel
hi my name is Eugene.  I have a question .  My skateboard remote is gone.  remotes are not sold in my country.  what should i do how can i use the skateboard .  we sell remotes from another company.  how can it be adjusted to my boosted mini .  help me solve the issue please
Evgeny Bubnov - Antwoord Deel
You can't use 3rd party remotes with proprietary Boosted products.
Tom Tamaira - Antwoord Deel
Verified this works with V2 and V3 remotes as well. I did a R29 and it works great. Thank you for the info.
Thayne Christiansen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 61
Altijd: 5,900
