Ga door naar hoofdinhoud
Boosted Board 1st Generation Belts Replacement
Wat je nodig hebt
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: stap 1, afbeelding 1 van 2 Boosted Board 1st Generation Belts Replacement, Rear Wheels: stap 1, afbeelding 2 van 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
    Vraag FixBot
    Voeg opmerking toe
  2. Boosted Board 1st Generation Belts Replacement: stap 2, afbeelding 1 van 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
    Vraag FixBot
    Voeg opmerking toe
  3. Boosted Board 1st Generation Belts Replacement: stap 3, afbeelding 1 van 2 Boosted Board 1st Generation Belts Replacement: stap 3, afbeelding 2 van 2
    • Remove the axel nut with a 1/2" socket wrench
    Vraag FixBot
    Voeg opmerking toe
  4. Boosted Board 1st Generation Belts Replacement: stap 4, afbeelding 1 van 3 Boosted Board 1st Generation Belts Replacement: stap 4, afbeelding 2 van 3 Boosted Board 1st Generation Belts Replacement: stap 4, afbeelding 3 van 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
    Vraag FixBot
    Voeg opmerking toe
  5. Boosted Board 1st Generation Belts Replacement, Belts: stap 5, afbeelding 1 van 3 Boosted Board 1st Generation Belts Replacement, Belts: stap 5, afbeelding 2 van 3 Boosted Board 1st Generation Belts Replacement, Belts: stap 5, afbeelding 3 van 3
    • Compress the motor mount back .
    • Slide the belt off the axle
    Vraag FixBot
    Voeg opmerking toe
  6. Boosted Board 1st Generation Belts Replacement: stap 6, afbeelding 1 van 1
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
    Vraag FixBot
    Voeg opmerking toe
  7. Boosted Board 1st Generation Belts Replacement: stap 7, afbeelding 1 van 3 Boosted Board 1st Generation Belts Replacement: stap 7, afbeelding 2 van 3 Boosted Board 1st Generation Belts Replacement: stap 7, afbeelding 3 van 3
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Emily Imfeld
532 Reputatie
4 handleidingen geschreven
Cal Poly, Team 15-7, Livingston Fall 2016 Lid van Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 2,027
