Inleiding
The voltage regulator board is an internal component and will require disassembly of the screwdriver casing. Due to disassembly of the casing, you will be required to use a few special tools listed in the outer casing replacement guide. Consult the outer casing replacement guide for instructions on removing the casing. Also, use caution when working on the screwdriver internally - always unplug the battery before replacing any components. This guide will also require a soldering iron and basic soldering skills for replacing the battery contact board. It is advised that you check all other components before replacing the voltage regulator board, as this is a last resort component to be replaced if screwdriver does not work.
Wat je nodig hebt
Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
Locate the negative terminal of the battery.
Remove the negative (black) wire by pulling back gently.
