Ga door naar hoofdinhoud
Black and Decker LI4000 Voltage Regulator Board Replacement
Wat je nodig hebt
  1. Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 2, afbeelding 1 van 1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 3, afbeelding 1 van 2 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 4, afbeelding 1 van 2 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 4, afbeelding 2 van 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
  5. Black and Decker LI4000 Voltage Regulator Board Replacement, Voltage Regulator Board: stap 5, afbeelding 1 van 2 Black and Decker LI4000 Voltage Regulator Board Replacement, Voltage Regulator Board: stap 5, afbeelding 2 van 2
    • Locate the negative terminal of the battery.
    • Remove the negative (black) wire by pulling back gently.
  6. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 6, afbeelding 1 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 6, afbeelding 2 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 6, afbeelding 3 van 3
    • Gently pull up on the end of the battery closest to the negative terminal. Pulling the battery up should reveal the positive (red) wire located on the opposite end of the battery.
    • To free battery, gently pull back on the positive (red) wire.
  7. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 7, afbeelding 1 van 2 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 7, afbeelding 2 van 2
    • Set battery aside in a safe place.
    • Locate the voltage regulator board near back midsection of the handle on the screwdriver.
    • Slowly pull up on the voltage regulator board.
    • Keep in mind the voltage regulator board is wired to all other boards. Use caution when removing to prevent causing damaging to wiring
  8. Black and Decker LI4000 Voltage Regulator Board Replacement: stap 8, afbeelding 1 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 8, afbeelding 2 van 3 Black and Decker LI4000 Voltage Regulator Board Replacement: stap 8, afbeelding 3 van 3
    • Locate the four soldering joints (two connected to battery contact board and two connected trigger/switch board).
    • iFixit has a quick tutorial on soldering here.
Conclusie
Nigel Leitzell
463 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-3, Baechle Spring 2016 Lid van IUPUI, Team 2-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 384
