Ga door naar hoofdinhoud
Beats Studio 2 Wireless Battery Replacement
Wat je nodig hebt
  1. Beats Studio 2 Wireless Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Beats Studio 2 Wireless Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
    Vraag FixBot
    Voeg opmerking toe
  2. Beats Studio 2 Wireless Battery Replacement: stap 2, afbeelding 1 van 2 Beats Studio 2 Wireless Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Beats Studio 2 Wireless Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
    Vraag FixBot
    Voeg opmerking toe
  4. Beats Studio 2 Wireless Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
    Vraag FixBot
    Voeg opmerking toe
  5. Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 1 van 3 Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 2 van 3 Beats Studio 2 Wireless Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jack Wilson
581 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 183
Altijd: 6,794
