Ga door naar hoofdinhoud
BLU Life XL Volume Control Buttons Replacement
Wat je nodig hebt
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: stap 1, afbeelding 1 van 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: stap 1, afbeelding 2 van 3 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: stap 1, afbeelding 3 van 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
    Vraag FixBot
    Voeg opmerking toe
  2. BLU Life XL Volume Control Buttons Replacement: stap 2, afbeelding 1 van 2 BLU Life XL Volume Control Buttons Replacement: stap 2, afbeelding 2 van 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. BLU Life XL Volume Control Buttons Replacement: stap 3, afbeelding 1 van 2 BLU Life XL Volume Control Buttons Replacement: stap 3, afbeelding 2 van 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
    Vraag FixBot
    Voeg opmerking toe
  4. BLU Life XL Volume Control Buttons Replacement: stap 4, afbeelding 1 van 3 BLU Life XL Volume Control Buttons Replacement: stap 4, afbeelding 2 van 3 BLU Life XL Volume Control Buttons Replacement: stap 4, afbeelding 3 van 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
James Whitlow
342 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G5, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 45
Altijd: 654
