Inleiding
Deze handleiding toont je hoe je een oude of kapotte batterij in je Asus ZenBook UX303U laptop kunt vervangen.
Gereedschap
Onderdelen
Verwijder de twee ronde, rubberen voeten aan de scharnierkant van de laptop.
Verwijder de elf 4 mm lange Phillips #00 schroeven uit het achterste paneel.
These screws on other models are Torx T5 or T6, not Phillips
T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
Trek de speakerkabel, met behulp van je vingers of een plastic openingstool, uit de vier bevestigingsklemmen.
Verwijder de speakers van de oude batterij.
This was a bit more fiddly than expected given the speaker arms are stuck to the battery
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
Breng je e-afval naar een door R2 of e-Stewards gecertificeerde recycler.
12 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
8 Opmerkingen
hello where I can buy a UX303U battery for asus?
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Same here, they are really small Torx on my Asus UX303U!
The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
Jon Kerridge - Antwoord
