Ga door naar hoofdinhoud
Asus X553MA-BPD07051 RAM Replacement
Wat je nodig hebt
  1. Asus X553MA-BPD07051 RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus X553MA-BPD07051 RAM Replacement: stap 2, afbeelding 1 van 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus X553MA-BPD07051 RAM Replacement: stap 3, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 3, afbeelding 2 van 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus X553MA-BPD07051 RAM Replacement: stap 4, afbeelding 1 van 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard. Lift white part upwards to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus X553MA-BPD07051 RAM Replacement: stap 5, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 5, afbeelding 2 van 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus X553MA-BPD07051 RAM Replacement: stap 6, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up and remove it completely from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus X553MA-BPD07051 RAM Replacement, Hard Drive: stap 7, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement, Hard Drive: stap 7, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws that are securing the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus X553MA-BPD07051 RAM Replacement: stap 8, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 8, afbeelding 2 van 2
    • Lift the hard drive up and pull it towards the screen so that it disconnects from the motherboard.
    • Use caution when disconnecting the hard drive from the motherboard, so that neither connector gets broken.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus X553MA-BPD07051 RAM Replacement, Optical Drive: stap 9, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement, Optical Drive: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the one 6.0 mm screw holding in the optical drive.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus X553MA-BPD07051 RAM Replacement: stap 10, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 10, afbeelding 2 van 2
    • Gently slide the optical drive out from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus X553MA-BPD07051 RAM Replacement, Motherboard: stap 11, afbeelding 1 van 3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: stap 11, afbeelding 2 van 3 Asus X553MA-BPD07051 RAM Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Remove the bundled cable connector that connects the fan to the motherboard using the plastic iFixit opening tool.
    • Remove the bundled cable connector that attaches the audio to the motherboard with the plastic iFixit opening tool.
    Vraag FixBot
    Voeg opmerking toe
  12. Asus X553MA-BPD07051 RAM Replacement: stap 12, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 12, afbeelding 2 van 2
    • Lift the metal clip holding the ZIF connector ribbon down.
    • Pull the ribbon out from the connector, away from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. Asus X553MA-BPD07051 RAM Replacement: stap 13, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 13, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the five 6.0 mm screws attaching the motherboard to the base of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  14. Asus X553MA-BPD07051 RAM Replacement: stap 14, afbeelding 1 van 1
    • Remove the tape from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  15. Asus X553MA-BPD07051 RAM Replacement: stap 15, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 15, afbeelding 2 van 2
    • Lift the metal clips holding the ZIF connector down.
    • Push the gold metal connector away from the motherboard.
    • Be careful not to break the connector.
    Vraag FixBot
    Voeg opmerking toe
  16. Asus X553MA-BPD07051 RAM Replacement: stap 16, afbeelding 1 van 2 Asus X553MA-BPD07051 RAM Replacement: stap 16, afbeelding 2 van 2
    • Lift the coaxial connector from the wifi chip with the plastic iFixit opening tool.
    Vraag FixBot
    Voeg opmerking toe
  17. Asus X553MA-BPD07051 RAM Replacement: stap 17, afbeelding 1 van 3 Asus X553MA-BPD07051 RAM Replacement: stap 17, afbeelding 2 van 3 Asus X553MA-BPD07051 RAM Replacement: stap 17, afbeelding 3 van 3
    • Lift the motherboard to remove it fully.
    • Do not pull too hard, the motherboard should come off easily once it has been separated from the base of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  18. Asus X553MA-BPD07051 RAM Replacement, RAM: stap 18, afbeelding 1 van 3 Asus X553MA-BPD07051 RAM Replacement, RAM: stap 18, afbeelding 2 van 3 Asus X553MA-BPD07051 RAM Replacement, RAM: stap 18, afbeelding 3 van 3
    • Remove the RAM by lifting and pulling it up from the back of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Stephanie DeCarvalho
973 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G4, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G4
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 55
Altijd: 2,745
