Ga door naar hoofdinhoud
Asus Q534U Battery Replacement
Wat je nodig hebt
  1. Asus Q534U Battery Replacement, Back Case Removal: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Q534U Battery Replacement: stap 2, afbeelding 1 van 2 Asus Q534U Battery Replacement: stap 2, afbeelding 2 van 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Q534U Battery Replacement: stap 3, afbeelding 1 van 2 Asus Q534U Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Q534U Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
18 andere personen hebben deze handleiding voltooid.
mmedina
827 Reputatie
2 handleidingen geschreven
7Gids Commentaar
Is there a website link where I can get a replacement battery for ASUS Q534 UXK ? Model year 2016.
Lalith Sharavan - Antwoord Deel
Can this laptop be used without a battery?
Thomas Zakrzewski - Antwoord Deel
Thomas, yes. I found that out by mistake when I didn’t fully connect/lock the new cable and had to go back in and reconnect it. Worked as usual on AC power.
mmedina - thanks for the step by step. Worked like a champ for me.
Jeff Nurkiewicz - Antwoord Deel
Dear IFixIt,
Thank you for this straightforward approach to changing the battery on my ASUS Laptop Model Q534UX BHI7T19. The first attempt was 100% successful!! I can say that opening the laptop base was a little scary, but your step-by-step details removed enough fear of me screwing something up that I went for it!! Having the right tools on hand went a long way to getting fast results and great outcome. I highly advise viewers to purchase a tool set to remove the tiny screws and a plastic pry tool set (the one I purchased from Amazon was only $18 and included both) to make this task almost effortless. Without your guidance, I never would have attempted this project. Thanks again!!
Do you have similar guidance for changing out the hard drives on the above ASUS??
sheri scott - Antwoord Deel
Hi Sheri, thanks for your message! We’re so happy this guide was helpful. We have a hard drive guide as well. Check out the Asus Q534U device page, there are several other guides in addition to the battery guide. Thanks again!
Sarah Westberg - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 86
Altijd: 14,123
