Ga door naar hoofdinhoud
Asus F555LA-AB31 Battery Replacement
Wat je nodig hebt
  1. Asus F555LA-AB31 Battery Replacement, CD Drive: stap 1, afbeelding 1 van 1
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 Battery Replacement: stap 2, afbeelding 1 van 2 Asus F555LA-AB31 Battery Replacement: stap 2, afbeelding 2 van 2
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 Battery Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 Battery Replacement: stap 4, afbeelding 1 van 2 Asus F555LA-AB31 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
  5. Asus F555LA-AB31 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Asus F555LA-AB31 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the four 4 mm Phillips #0 screws securing the battery.
  6. Asus F555LA-AB31 Battery Replacement: stap 6, afbeelding 1 van 2 Asus F555LA-AB31 Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift up battery and remove it from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 4,390
