Ga door naar hoofdinhoud
Apple TV 3rd Generation Status LED Replacement
Wat je nodig hebt
    1. Apple TV 3rd Generation Status LED Replacement, Snap-on Base: stap 1, afbeelding 1 van 1
      • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
      Vraag FixBot
      Voeg opmerking toe
    2. Apple TV 3rd Generation Status LED Replacement: stap 2, afbeelding 1 van 1
      • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple TV 3rd Generation Status LED Replacement, Logic Board: stap 3, afbeelding 1 van 1
      • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
      Vraag FixBot
      Voeg opmerking toe
    2. Apple TV 3rd Generation Status LED Replacement: stap 4, afbeelding 1 van 2 Apple TV 3rd Generation Status LED Replacement: stap 4, afbeelding 2 van 2
      • Disconnect the power supply connector from the logic board with a spudger.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple TV 3rd Generation Status LED Replacement, Power Supply: stap 5, afbeelding 1 van 2 Apple TV 3rd Generation Status LED Replacement, Power Supply: stap 5, afbeelding 2 van 2
      • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
      • You may now be able to remove the power supply with a spudger.
      • Do not pull the wires to remove the power supply. The connector is fragile.
      • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
      Vraag FixBot
      Voeg opmerking toe
    1. Apple TV 3rd Generation Status LED Replacement, Status LED: stap 6, afbeelding 1 van 2 Apple TV 3rd Generation Status LED Replacement, Status LED: stap 6, afbeelding 2 van 2
      • The last remaining part in the Apple TV is the status LED. You can remove this part with your plastic spudger.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Vincent Monteil
7.031 Reputatie
19 handleidingen geschreven
1Gids Commentaar
Step 2: “caring not to break….”. Thanks, great guide. David
David Apimerika - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 52
Altijd: 3,745
