Inleiding
This guide replaces Aoson R103 Speakers, which will require soldering. This guide can be used to fix distorted or broken audio and will require you to dismantle and redo electrical connections.
Be sure to disconnect the power from the battery to ensure you do not damage the device or injur yourself via electric shock. Exercise caution while soldering so that you do not burn anything.
Wat je nodig hebt
Turn off the device using the power button.
Using fingernails/a pry tool, separate the back panel of the device. This may require some force, as they are connected by push tabs.
These are the motherboard connections to the speaker, which will be needed later.
These are the two speakers, which are attached to a plastic piece via a screw.
Remove the 4.0mm long Phillips #00 screw where the plastic disconnects.
Één andere persoon heeft deze handleiding voltooid.
