Inleiding
This is a simple guide on the replacement of the speaker within the Anker SoundCore 2. You may need to replace the speaker if it will not play at all, if there is sound delay, or if the speaker has blown out. Take a look at our troubleshooting page to see if you need to replace your speaker or not.
Wat je nodig hebt
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Use your hand to remove the speakers.
4 andere personen hebben deze handleiding voltooid.
13Gids Commentaar
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
@philcuchetti I have a soundcore select 1 which is an older model and it seems to have the same speaker which I found here https://www.aliexpress.com/item/10050091...
Do someone get a new speaker? I need to buy one!
