Ga door naar hoofdinhoud
Anker SoundCore 2 Battery Replacement
Wat je nodig hebt
  1. Anker SoundCore 2 Battery Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard to expose the battery.
  4. Anker SoundCore 2 Battery Replacement: stap 4, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a nylon spudger to remove the battery from the speaker casing.
    • Caution: Do not use metal prying tools on a battery—these can puncture an unprotected battery, potentially causing a fire.
    • The battery is glued down so it may be difficult to remove.
  5. Anker SoundCore 2 Battery Replacement: stap 5, afbeelding 1 van 2 Anker SoundCore 2 Battery Replacement: stap 5, afbeelding 2 van 2
    • Unplug the wire that connects the battery with the motherboard.
    • When replacing the battery, plug in the new battery where the old one was plugged in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
It would be nice to have the specifications of the battery so availability can be checked before disassembly.
Michael Anderson - Antwoord
7.2V, 2550 mAh, 18.36 Watt - Hour
Kang Le - Antwoord
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?
abdurreheembakir - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 262
Altijd: 3,969
