Ga door naar hoofdinhoud
Anker 2.4G Wireless Mouse Sensor Replacement
Wat je nodig hebt
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: stap 1, afbeelding 1 van 1
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
    Vraag FixBot
    Voeg opmerking toe
  2. Anker 2.4G Wireless Mouse Sensor Replacement: stap 2, afbeelding 1 van 1
    • Using your Phillips screwdriver, remove the four screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Anker 2.4G Wireless Mouse Sensor Replacement: stap 3, afbeelding 1 van 2 Anker 2.4G Wireless Mouse Sensor Replacement: stap 3, afbeelding 2 van 2
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
    Vraag FixBot
    Voeg opmerking toe
  4. Anker 2.4G Wireless Mouse Sensor Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
    Vraag FixBot
    Voeg opmerking toe
  5. Anker 2.4G Wireless Mouse Sensor Replacement: stap 5, afbeelding 1 van 1
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    Vraag FixBot
    Voeg opmerking toe
  6. Anker 2.4G Wireless Mouse Sensor Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
    Vraag FixBot
    Voeg opmerking toe
  7. Anker 2.4G Wireless Mouse Sensor Replacement: stap 7, afbeelding 1 van 1
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Ryan
152 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-39, Maness Winter 2014 Lid van Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 66
Altijd: 8,496
