Inleiding
The speaker allows audio from the device, however, overtime the speaker may stop working due to damage from dirt and dust or long-term use of the high volume. This guide demonstrates how to replace the speaker.
Wat je nodig hebt
Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
Use your fingernails or tweezers to gently remove the battery connector from its socket.
Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
Take a pair of angled tweezers and put it in the square hole next to the tweezers.
Rotate the tweezer tip clockwise to push the speaker out of the chassis.
Remove the speaker.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
