Ga door naar hoofdinhoud
Amazon Echo Show 10 3rd Gen Tweeter Replacement
Wat je nodig hebt
    1. Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: stap 1, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: stap 1, afbeelding 2 van 2
      • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 2, afbeelding 1 van 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 3, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 3, afbeelding 2 van 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 4, afbeelding 1 van 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      Vraag FixBot
      Voeg opmerking toe
    5. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 5, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 5, afbeelding 2 van 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      Vraag FixBot
      Voeg opmerking toe
    6. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 6, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 6, afbeelding 2 van 2
      • Rotate the device to lay on its side with the tweeter's exterior facing you.
      • Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
      Vraag FixBot
      Voeg opmerking toe
    7. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 7, afbeelding 1 van 1
      • Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
      Vraag FixBot
      Voeg opmerking toe
    8. Amazon Echo Show 10 3rd Gen Tweeter Replacement: stap 8, afbeelding 1 van 1
      • Remove the tweeter.
      • Repeat the previous steps if you are removing the other tweeter.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Macy Ormand
1.101 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 501
