Ga door naar hoofdinhoud
Amazon Echo Show 10 3rd Gen Display Replacement
Wat je nodig hebt
    1. Amazon Echo Show 10 3rd Gen Display Replacement, Display: stap 1, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Display Replacement, Display: stap 1, afbeelding 2 van 2
      • With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set aside.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Echo Show 10 3rd Gen Display Replacement: stap 2, afbeelding 1 van 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Echo Show 10 3rd Gen Display Replacement: stap 3, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Display Replacement: stap 3, afbeelding 2 van 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Echo Show 10 3rd Gen Display Replacement: stap 4, afbeelding 1 van 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      Vraag FixBot
      Voeg opmerking toe
    5. Amazon Echo Show 10 3rd Gen Display Replacement: stap 5, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Display Replacement: stap 5, afbeelding 2 van 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      Vraag FixBot
      Voeg opmerking toe
    6. Amazon Echo Show 10 3rd Gen Display Replacement: stap 6, afbeelding 1 van 1
      • Tilt the device so that the underside of the display and its neck are facing you.
      • You may need help holding it in this position. Alternatively, you could place the device on a soft surface so it doesn't get damaged.
      • Use a T6 Torx screwdriver to remove the two 5mm screws from the underside of the display neck.
      Vraag FixBot
      Voeg opmerking toe
    7. Amazon Echo Show 10 3rd Gen Display Replacement: stap 7, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Display Replacement: stap 7, afbeelding 2 van 2
      • Lift the plate up to remove it from the neck of the device.
      • Set it aside for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    8. Amazon Echo Show 10 3rd Gen Display Replacement: stap 8, afbeelding 1 van 1
      • Use an opening tool to flip up the small locking flap on the ribbon cable connector located in the center of the exposed underside of the display neck.
      • Gently pull the cable out.
      Vraag FixBot
      Voeg opmerking toe
    9. Amazon Echo Show 10 3rd Gen Display Replacement: stap 9, afbeelding 1 van 1
      • Tilt the device so it is in the upright position.
      • Use a TR10 Torx Security screwdriver to remove the four 11 mm screws from the top of the display neck.
      Vraag FixBot
      Voeg opmerking toe
    10. Amazon Echo Show 10 3rd Gen Display Replacement: stap 10, afbeelding 1 van 2 Amazon Echo Show 10 3rd Gen Display Replacement: stap 10, afbeelding 2 van 2
      • Gently lift the display and its connecting neck off of the base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Macy Ormand
1.101 Reputatie
6 handleidingen geschreven
6Gids Commentaar
any idea where to purchase a replacement display?
Don Jackson - Antwoord Deel
Were you able to source a replacement display? I'm having troubles finding one. Thanks
Jeg4 - Antwoord Deel
where can I buy a replacement display for echo 10 3rd gen?
Tomasz K. - Antwoord Deel
@tomaszk64280 por la plataforma de amazon, pero no aparece el tutorial para cambiar solo la pantalla
ARIAS SEGUROS Y CIA LTDA - Antwoord Deel
Wenn ihr eine Quelle gefunden habt wäre eine info schön ich suche nun auch nach einem kleinen missgeschick...
Jan Pfotenhauer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 95
Altijd: 2,667
