Ga door naar hoofdinhoud
Alienware AW610M Side Button Replacement
Wat je nodig hebt
    1. Alienware AW610M Side Button Replacement, Battery: stap 1, afbeelding 1 van 3 Alienware AW610M Side Button Replacement, Battery: stap 1, afbeelding 2 van 3 Alienware AW610M Side Button Replacement, Battery: stap 1, afbeelding 3 van 3
      • Power off the mouse and disconnect any wired connections.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware AW610M Side Button Replacement: stap 2, afbeelding 1 van 2 Alienware AW610M Side Button Replacement: stap 2, afbeelding 2 van 2
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware AW610M Side Button Replacement: stap 3, afbeelding 1 van 2 Alienware AW610M Side Button Replacement: stap 3, afbeelding 2 van 2
      • Remove the four 6.5 mm screws using a Y1 Tri-Point screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Alienware AW610M Side Button Replacement: stap 4, afbeelding 1 van 2 Alienware AW610M Side Button Replacement: stap 4, afbeelding 2 van 2
      • Using an opening tool, gently pry apart the two halves of the mouse case. Start at the seam and work your way around until the housing is separated.
      • Don't pull the halves completely apart, as internal wires still connect them.
      Vraag FixBot
      Voeg opmerking toe
    5. Alienware AW610M Side Button Replacement: stap 5, afbeelding 1 van 3 Alienware AW610M Side Button Replacement: stap 5, afbeelding 2 van 3 Alienware AW610M Side Button Replacement: stap 5, afbeelding 3 van 3
      • Remove the battery pack inside the mouse.
      • If you are having trouble, use a small flat tool to help ease it out.
      • The battery is lightly glued to the mouse, so ease it out gently to avoid breaking the battery or wiring
      Vraag FixBot
      Voeg opmerking toe
    6. Alienware AW610M Side Button Replacement: stap 6, afbeelding 1 van 2 Alienware AW610M Side Button Replacement: stap 6, afbeelding 2 van 2
      • Remove the old battery from its spot. Lift the wire connector away from the mainboard to disconnect it.
      • Make sure all wires are inside the mouse before sealing it shut for easy reassembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Alienware AW610M Side Button Replacement, Side Button: stap 7, afbeelding 1 van 2 Alienware AW610M Side Button Replacement, Side Button: stap 7, afbeelding 2 van 2
      • Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
      • Detach the cable connector, and remove the scroll wheel.
      • Gently detach the last connector using your fingers.
      • Be careful when unplugging all connectors to prevent tearing them.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware AW610M Side Button Replacement: stap 8, afbeelding 1 van 1
      • Turn the large shell casing so that the inside faces you.
      • Using a Phillips #1 screwdriver, remove six 5.4 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware AW610M Side Button Replacement: stap 9, afbeelding 1 van 2 Alienware AW610M Side Button Replacement: stap 9, afbeelding 2 van 2
      • Using your fingers, disconnect the plastic tab in the middle of the large shell casing to access the side buttons.
      Vraag FixBot
      Voeg opmerking toe
    4. Alienware AW610M Side Button Replacement: stap 10, afbeelding 1 van 3 Alienware AW610M Side Button Replacement: stap 10, afbeelding 2 van 3 Alienware AW610M Side Button Replacement: stap 10, afbeelding 3 van 3
      • Remove the side button on the inner side of the wall using a plastic opening tool.
      • Be gentle prying the side buttons off to avoid breaking them.
      • When reassembling, position the new side button assembly into the slot, aligning it with tabs. Snap it securely into place using a plastic opening tool or your fingers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Darby Brandt
391 Reputatie
2 handleidingen geschreven
Texas Tech, Team 46-4, Johansen Fall 2025 Lid van Texas Tech, Team 46-4, Johansen Fall 2025
TTU-JOHANSEN-F25S46G4
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 265
