Inleiding
This guide will show you how to replace the battery for your Alienware 17 R3. Be sure you have all the required tools before you begin.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Turn the computer off.
Disconnect the charging cable from the computer.
20 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Very helpful and concise. Worked very well for me. Many Thanks
After putting everything back together I found my didn't HDD work. It was simply that the other end of the HDD cable had become disconnected.
I'd recommend disconnecting this before removing the HDD housing so it doesn't snag (it's actually shown as disconnected in step 10).
