Ga door naar hoofdinhoud
Accessing Logicboard
Wat je nodig hebt
  1. Accessing Logicboard, Front and Back Cover: stap 1, afbeelding 1 van 2 Accessing Logicboard, Front and Back Cover: stap 1, afbeelding 2 van 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
    Vraag FixBot
  2. Accessing Logicboard: stap 2, afbeelding 1 van 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
    Vraag FixBot
  3. Accessing Logicboard: stap 3, afbeelding 1 van 2 Accessing Logicboard: stap 3, afbeelding 2 van 2
    • Carefully pull the back of casing away from the front.
    Vraag FixBot
  4. Accessing Logicboard: stap 4, afbeelding 1 van 3 Accessing Logicboard: stap 4, afbeelding 2 van 3 Accessing Logicboard: stap 4, afbeelding 3 van 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
    Vraag FixBot
  5. Accessing Logicboard: stap 5, afbeelding 1 van 2 Accessing Logicboard: stap 5, afbeelding 2 van 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    Vraag FixBot
  6. Accessing Logicboard, Logicboard: stap 6, afbeelding 1 van 2 Accessing Logicboard, Logicboard: stap 6, afbeelding 2 van 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
    Vraag FixBot
  7. Accessing Logicboard: stap 7, afbeelding 1 van 2 Accessing Logicboard: stap 7, afbeelding 2 van 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
    Vraag FixBot
  8. Accessing Logicboard: stap 8, afbeelding 1 van 1
    • Pull the cover plate off for the two power cord jacks.
    Vraag FixBot
  9. Accessing Logicboard: stap 9, afbeelding 1 van 3 Accessing Logicboard: stap 9, afbeelding 2 van 3 Accessing Logicboard: stap 9, afbeelding 3 van 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    Vraag FixBot
  10. Accessing Logicboard: stap 10, afbeelding 1 van 1
    • Remove the orange tape on top of the SD cardholder.
    Vraag FixBot
  11. Accessing Logicboard: stap 11, afbeelding 1 van 1
    • Open the battery cover.
    Vraag FixBot
  12. Accessing Logicboard: stap 12, afbeelding 1 van 2 Accessing Logicboard: stap 12, afbeelding 2 van 2
    • Lift the indicated plastic piece off.
    Vraag FixBot
  13. Accessing Logicboard: stap 13, afbeelding 1 van 2 Accessing Logicboard: stap 13, afbeelding 2 van 2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
    Vraag FixBot
  14. Accessing Logicboard: stap 14, afbeelding 1 van 1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
    Vraag FixBot
  15. Accessing Logicboard: stap 15, afbeelding 1 van 3 Accessing Logicboard: stap 15, afbeelding 2 van 3 Accessing Logicboard: stap 15, afbeelding 3 van 3
    • Carefully lift up SD cardholder to reveal logicboard.
    Vraag FixBot
Conclusie
Nicole Wong
371 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-29, Regan Winter 2011 Lid van Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 90
Altijd: 1,873
