Ga door naar hoofdinhoud
AYL SoundFit Motherboard Replacement
Wat je nodig hebt
  1. AYL SoundFit Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. AYL SoundFit Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
    Vraag FixBot
    Voeg opmerking toe
  3. AYL SoundFit Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
    Vraag FixBot
    Voeg opmerking toe
  4. AYL SoundFit Motherboard Replacement: stap 4, afbeelding 1 van 2 AYL SoundFit Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. AYL SoundFit Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. AYL SoundFit Motherboard Replacement: stap 6, afbeelding 1 van 3 AYL SoundFit Motherboard Replacement: stap 6, afbeelding 2 van 3 AYL SoundFit Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
john
171 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Harley Spring 2016 Lid van IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Leden
10 handleidingen geschreven
3Gids Commentaar
Where do u get a new motherboard at?
calvinsmith522 - Antwoord Deel
Anybody know where to get a motherboard?
David Whitman - Antwoord Deel
Where do I get a motherboard?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 29
Altijd: 2,031
