Inleiding
Use this guide to replace the left SSD on your ASUS TUF Gaming F15 FX506HEB-DB74.
Before you perform this repair, if at all possible, back up your existing SSD. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Wat je nodig hebt
Remove the 11 Phillips screws securing the lower case:
Seven 11.6 mm screws
Two 14.6 mm screws
Two 6.1 mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the right edge to release the clips securing the lower case.
Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
Use your fingers to move the plastic that covers the battery connector out of the way.
Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
Use a Phillips screwdriver to remove the 3.6 mm screw securing the left SSD and its cover.
Slide the SSD cover off of the SSD by grabbing the edges near the screw indent and pulling away from the SSD.
Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
