Ga door naar hoofdinhoud
ASUS ROG Raikiri Pro Case Replacement
Wat je nodig hebt
  1. ASUS ROG Raikiri Pro Case Replacement, Battery: stap 1, afbeelding 1 van 3 ASUS ROG Raikiri Pro Case Replacement, Battery: stap 1, afbeelding 2 van 3 ASUS ROG Raikiri Pro Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS ROG Raikiri Pro Case Replacement: stap 2, afbeelding 1 van 3 ASUS ROG Raikiri Pro Case Replacement: stap 2, afbeelding 2 van 3 ASUS ROG Raikiri Pro Case Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS ROG Raikiri Pro Case Replacement: stap 3, afbeelding 1 van 2 ASUS ROG Raikiri Pro Case Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS ROG Raikiri Pro Case Replacement: stap 4, afbeelding 1 van 2 ASUS ROG Raikiri Pro Case Replacement: stap 4, afbeelding 2 van 2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS ROG Raikiri Pro Case Replacement: stap 5, afbeelding 1 van 2 ASUS ROG Raikiri Pro Case Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. ASUS ROG Raikiri Pro Case Replacement: stap 6, afbeelding 1 van 2 ASUS ROG Raikiri Pro Case Replacement: stap 6, afbeelding 2 van 2
    • Use a spudger to carefully remove the board and left rumble motor.
    Vraag FixBot
    Voeg opmerking toe
  7. ASUS ROG Raikiri Pro Case Replacement: stap 7, afbeelding 1 van 2 ASUS ROG Raikiri Pro Case Replacement: stap 7, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  8. ASUS ROG Raikiri Pro Case Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the battery from its enclosure.
    Vraag FixBot
    Voeg opmerking toe
  9. ASUS ROG Raikiri Pro Case Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the right board.
    Vraag FixBot
    Voeg opmerking toe
  10. ASUS ROG Raikiri Pro Case Replacement: stap 10, afbeelding 1 van 1
    • Use a spudger to carefully remove the right board.
    Vraag FixBot
    Voeg opmerking toe
  11. ASUS ROG Raikiri Pro Case Replacement: stap 11, afbeelding 1 van 1
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    Vraag FixBot
    Voeg opmerking toe
  12. ASUS ROG Raikiri Pro Case Replacement: stap 12, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver to remove the six 8 mm screws holding the motherboard to the case.
    Vraag FixBot
    Voeg opmerking toe
  13. ASUS ROG Raikiri Pro Case Replacement: stap 13, afbeelding 1 van 1
    • Use tweezers to disconnect the ribbon cable from the top of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  14. ASUS ROG Raikiri Pro Case Replacement: stap 14, afbeelding 1 van 1
    • Remove the motherboard from the case.
    • Be careful when removing the motherboard so you don't damage the USB-C connector.
    Vraag FixBot
    Voeg opmerking toe
  15. ASUS ROG Raikiri Pro Case Replacement, Case: stap 15, afbeelding 1 van 1
    • Flip the top case so the front is facing down and pop out the action buttons if they don't fall out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 92
Altijd: 793
