Ga door naar hoofdinhoud
ASUS ROG Raikiri Pro Battery Replacement
Wat je nodig hebt
  1. ASUS ROG Raikiri Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 3 ASUS ROG Raikiri Pro Battery Replacement, Battery: stap 1, afbeelding 2 van 3 ASUS ROG Raikiri Pro Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS ROG Raikiri Pro Battery Replacement: stap 2, afbeelding 1 van 3 ASUS ROG Raikiri Pro Battery Replacement: stap 2, afbeelding 2 van 3 ASUS ROG Raikiri Pro Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS ROG Raikiri Pro Battery Replacement: stap 3, afbeelding 1 van 2 ASUS ROG Raikiri Pro Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS ROG Raikiri Pro Battery Replacement: stap 4, afbeelding 1 van 2 ASUS ROG Raikiri Pro Battery Replacement: stap 4, afbeelding 2 van 2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS ROG Raikiri Pro Battery Replacement: stap 5, afbeelding 1 van 2 ASUS ROG Raikiri Pro Battery Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. ASUS ROG Raikiri Pro Battery Replacement: stap 6, afbeelding 1 van 2 ASUS ROG Raikiri Pro Battery Replacement: stap 6, afbeelding 2 van 2
    • Use a spudger to carefully remove the board and left rumble motor.
    Vraag FixBot
    Voeg opmerking toe
  7. ASUS ROG Raikiri Pro Battery Replacement: stap 7, afbeelding 1 van 2 ASUS ROG Raikiri Pro Battery Replacement: stap 7, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  8. ASUS ROG Raikiri Pro Battery Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the battery from its enclosure.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 60
Altijd: 828
