Ga door naar hoofdinhoud
ASUS Chromebook C424MA-DH48F Touchpad Replacement
Wat je nodig hebt
  1. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: stap 1, afbeelding 1 van 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: stap 2, afbeelding 3 van 3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: stap 3, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: stap 3, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement, Battery: stap 3, afbeelding 3 van 3
    • Carefully use the plastic prying tool and pop up the locking bar and lift the connector off with your hand.
  4. ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 4, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 4, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 4, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the six 4.1 mm screws that secure the battery.
    • The two screw holes (marked in orange) on the bottom won't have screws associated with them since they were removed earlier when the base was removed.
    • Unseat the speaker cable from the black plastic hooks on the lower side of the battery.
    • Lift the battery up and out of the chassis.
  5. ASUS Chromebook C424MA-DH48F Touchpad Replacement, Touchpad: stap 5, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the three 1.9 mm screws that secure the touchpad.
  6. ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Carefully peel off the gray tape on the touchpad.
  7. ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 7, afbeelding 1 van 2 ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Use an opening tool to flip up the black ZIF locking flap that secures the ribbon cable connector to the touchpad.
    • Pinch both sides of the ribbon cable connector and gently pull straight back to disconnect the touchpad.
    • Be very careful as the ribbon cable is fragile and can rip easily.
  8. ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 8, afbeelding 1 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 8, afbeelding 2 van 3 ASUS Chromebook C424MA-DH48F Touchpad Replacement: stap 8, afbeelding 3 van 3
    • Lift the touchpad up and out of the chassis.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Anthony Wink
401 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 41
