Ga door naar hoofdinhoud
APEX TM785CH Battery Replacement
Wat je nodig hebt
    1. APEX TM785CH Battery Replacement, Back Casing: stap 1, afbeelding 1 van 2 APEX TM785CH Battery Replacement, Back Casing: stap 1, afbeelding 2 van 2
      • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
      • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
      • Move along the top edge of the tablet and repeat the step above.
      • Pull the back cover away from the tablet body to completely remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. APEX TM785CH Battery Replacement, Battery: stap 2, afbeelding 1 van 2 APEX TM785CH Battery Replacement, Battery: stap 2, afbeelding 2 van 2
      • With the back cover removed, you can now see the battery.
      • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Brian Graschel
823 Reputatie
6 handleidingen geschreven
Baylor, Team 4-1, Williams Spring 2015 Lid van Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 2,521
