Inleiding
Use this guide to replace the battery cartridge in your APC uninterruptible power supply model SMT1500RM2UC.
Note: The individual battery cells are adhered to a metal battery tray. They must be replaced as one assembly, called the battery cartridge.
Wat je nodig hebt
Press in one of the clips until it releases.
Pull the edge of the front bezel away from the device until the clip comes out of its slot.
Gently pull the unclipped edge of the bezel away from the device until the other clip releases.
Remove the front bezel.
Pull the battery disconnect string out of its recess in the middle of the front edge.
Use the battery disconnect string to pull the yellow connector completely out of its socket, disconnecting the battery.
Use a Phillips screwdriver to remove the six 11.2 mm‑long screws securing the battery cartridge.
Slide the battery cartridge out of the device until it stops.
