Inleiding
If your ANKER SoundCore does not charge, your charging port may be broken. If you wish to replace your device’s charging port, you can follow this step-by-step guide.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
You will need an iFixit opening tool, Phillips #0 screwdriver, metal spludger, and iFixit opening pick. Soldering experience is needed.
Wat je nodig hebt
Use the plastic opening tool to pry off the screen.
Remove the screen from the device.
Desolder the charging port from the circuit board.
Solder a new charging port in place of the old one.
The red box in the picture is highlighting the audio port not the charging port.
3 andere personen hebben deze handleiding voltooid.
