Ga door naar hoofdinhoud
4Sight 9 Screen Replacement
Wat je nodig hebt
    1. 4Sight 9 Screen Replacement, Cover: stap 1, afbeelding 1 van 2 4Sight 9 Screen Replacement, Cover: stap 1, afbeelding 2 van 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. 4Sight 9 Screen Replacement: stap 2, afbeelding 1 van 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Vraag FixBot
      Voeg opmerking toe
    3. 4Sight 9 Screen Replacement: stap 3, afbeelding 1 van 2 4Sight 9 Screen Replacement: stap 3, afbeelding 2 van 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Vraag FixBot
      Voeg opmerking toe
    1. 4Sight 9 Screen Replacement, Battery: stap 4, afbeelding 1 van 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Vraag FixBot
      Voeg opmerking toe
    2. 4Sight 9 Screen Replacement: stap 5, afbeelding 1 van 2 4Sight 9 Screen Replacement: stap 5, afbeelding 2 van 2
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      Vraag FixBot
      Voeg opmerking toe
    1. 4Sight 9 Screen Replacement, Screen: stap 6, afbeelding 1 van 2 4Sight 9 Screen Replacement, Screen: stap 6, afbeelding 2 van 2
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      Vraag FixBot
      Voeg opmerking toe
    2. 4Sight 9 Screen Replacement: stap 7, afbeelding 1 van 2 4Sight 9 Screen Replacement: stap 7, afbeelding 2 van 2
      • Remove the second electrical ribbon from the motherboard using the same technique used to remove first ribbon.
      Vraag FixBot
      Voeg opmerking toe
    3. 4Sight 9 Screen Replacement: stap 8, afbeelding 1 van 1
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      Vraag FixBot
      Voeg opmerking toe
    4. 4Sight 9 Screen Replacement: stap 9, afbeelding 1 van 2 4Sight 9 Screen Replacement: stap 9, afbeelding 2 van 2
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      Vraag FixBot
      Voeg opmerking toe
    5. 4Sight 9 Screen Replacement: stap 10, afbeelding 1 van 2 4Sight 9 Screen Replacement: stap 10, afbeelding 2 van 2
      • With the motherboard facing you, look to the bottom left corner, pull on the camera to completely free the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. 4Sight 9 Screen Replacement: stap 11, afbeelding 1 van 1
      • Using your fingers, gently lift the motherboard and battery.
      Vraag FixBot
      Voeg opmerking toe
    7. 4Sight 9 Screen Replacement: stap 12, afbeelding 1 van 3 4Sight 9 Screen Replacement: stap 12, afbeelding 2 van 3 4Sight 9 Screen Replacement: stap 12, afbeelding 3 van 3
      • Insert plastic prying tool under screen and exert pressure, pulling upward.
      • Repeat this step around each corner of the screen until it pops off.
      • Ensure screen is free from all black tabs holding it in place.
      Vraag FixBot
      Voeg opmerking toe
    8. 4Sight 9 Screen Replacement: stap 13, afbeelding 1 van 1
      • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes
      • Remove plastic film from glass frame
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 3,435
