Ga door naar hoofdinhoud
4Sight 9 Battery Replacement
Wat je nodig hebt
    1. 4Sight 9 Battery Replacement, Cover: stap 1, afbeelding 1 van 2 4Sight 9 Battery Replacement, Cover: stap 1, afbeelding 2 van 2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. 4Sight 9 Battery Replacement: stap 2, afbeelding 1 van 1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      Vraag FixBot
      Voeg opmerking toe
    3. 4Sight 9 Battery Replacement: stap 3, afbeelding 1 van 2 4Sight 9 Battery Replacement: stap 3, afbeelding 2 van 2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      Vraag FixBot
      Voeg opmerking toe
    1. 4Sight 9 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      Vraag FixBot
      Voeg opmerking toe
    2. 4Sight 9 Battery Replacement: stap 5, afbeelding 1 van 2 4Sight 9 Battery Replacement: stap 5, afbeelding 2 van 2
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 40
Altijd: 2,229
