Battery
1 Antwoord 0 Score |
Can I replace the Graphics card? |
Geen antwoorden 0 Score |
password for HDD/SSD Toshiba C55-B5382 |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
The Toshiba Satellite C55-B5302 laptop is one of the latest models in the Satellite series, sold in the U.S. between October 25th, 2012 and July 29th 2015.
Identification
For easy identification, you can find "Toshiba Satellite C55-B5302" printed on a sticker affixed to the bottom of the laptop, above the serial number. This model's external case is textured resin in jet black.
Specifications
Here are some key features of this model:
- Operating System: Microsoft Windows 8.1 pre-installed
- Display: 15.6” / 39.6 cm, widescreen 16:9 aspect ratio, LED backlit
- Processor: 64-bit Celeron N2840, 2.16 GHz (2.58 GHz max turbo speed), dual-core, with 1MB cache
- Memory: 4GB , 1333 MHz DDR3L SDRAM
- Storage: 500GB Serial ATA-300 hard drive
- CD/DVD Drive:
- Read: 24x (CD) / 8x (DVD)
- Write: 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- Rewrite: 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Networking: Ethernet / Wi-Fi
- Battery: 4-cell lithium ion
- Standard keyboard: US (QWERTY)
- AC adapter:
- Input: AC 120/230 V (50/60 Hz)
- Output: 45 Watt, 19 V, 2.37 A
- Interfaces:
- 1 x USB 3.0
- 1 x LAN
- 1 x VGA
- 1 x Headphone / microphone combo jack
- 2 x USB 2.0
- 1 x HDMI
- 1 x SD card reader
- Dimensions: 15" wide, 10.2" deep, 1" high
- Weight: 4.85 Lbs
- Warranty: 1 year manufacturers warranty
- Webcam: yes
Troubleshooting
If you are having difficulty with your Toshiba Satellite C55-B5302 laptop, please refer to the troubleshooting page.
