Ga door naar hoofdinhoud
Inleiding
These are the steps for removing the battery from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and your laptop is not plugged in. If your battery is hot to the touch, wait until it has cooled down before removing it. Additionally, if the battery seems to be bulging or cracked, it should be disposed of properly and a not reinserted into your laptop. The battery is easy to remove and will only take you a few minutes.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip laptop upside down so you can see the screws. Flip laptop upside down so you can see the screws.
    • Flip laptop upside down so you can see the screws.
  2. PC Laptop batterijen
    An easy fix for a big power boost.
    Nu winkelen
    Nu winkelen
  3. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  4. Pull the battery from the back of the laptop for removal from the laptop.
    • Pull the battery from the back of the laptop for removal from the laptop.
Conclusie
Jacob Mayes
217 Reputatie
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 11
Altijd: 135
