Inleiding
These steps will help guide you to removing the keyboard from your Toshiba Satellite C55-B5302 laptop. This will be more of a time consuming project. Make sure you have all the correct tools.
Wat je nodig hebt
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
