Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
How to reduce 8+ gigabytes of yellow "other" in the capacity?
It's taking up a precious 8.8 of my 32 gigs. I have tried restoring (from a backup) to no avail. Restoring as a new phone would result in losing years worth of text message history. Please help! Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Nathan, the storage capacity is probably at 8.8GB because of the stuff that you have on there for years. If you want to free up the memory, you have to move the stuff of your phone and onto a something more permanent. There is no way to free anything up if you do not move it off the phone. Time for some house cleaning :) Commercial software is available for doing this, like this one or you can try the trial version from here. Hope this helps, good luck
Was dit antwoord nuttig?
Score 2
If the text messages are important to you, you should consider getting software that can copy them to your computer. After you do that, you can restore as new.
Score 1
Go to the apps store and buy an app called sms export - downloads all your text msgs. needed my texts as evidence in court and i used it.
Voeg je antwoord toe
Nathan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 4,215
