Ga door naar hoofdinhoud
No chime upon startup
I just reassembled my laptop, and I do not hear the apple "chime" upon start up. The computer does seem to be functioning normally, but I always heard the chime in previous macs I have owned.
Am I being paranoid, or should I just ignore this? Thanks for any input.
Is dit een goede vraag?
Score 1
1 Opmerking
Does the computer work fine? or will it not turn on? Do you hear sounds when you turn the volume up or down, can you not hear any sound? If you can't hear anything, chances are that you might have unplugged the internal speakers somewhere during the keyboard replacement.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
See if it boots up, are you using the original keyboard, or the replacement one you mentioned in annother question? Try to put in the original keyboard if you haven't already. Check your RAM, try to reseat it, since you could have knocked it out of place. Also try reseting the PMU, and the PRAM.
Was dit antwoord nuttig?
Score 2
Check that your volume is not muted.
Score 1
2 opmerkingen:
or speaker wire disconnected/broken.
door
Yes or course, that too, but sometimes the most obvious is the least obvious
door
Thanks for all the help. The computer seems to be running fine. I played a few songs through itunes and they came through the computer speakers fine, but still no chime when I boot the computer. I am at a lost as to why this is happening. I am hoping someone with a little more experience can explain this to me. Again, thank you for all your help.
Charl
1 Opmerking:
I had a similar problem and cured it by reseating the ram and as Chris said reseting the PMU. Ralph
door
Voeg je antwoord toe
Charl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,373
