Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
The user interface is unresponsive.
The user interface is sometimes unresponsive; I have to restart the device several times. The user interface is sometimes unresponsive; I have to restart the device several times.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Just to clarify, generally when people talk about a Xiaomi Note 10, they're technically referring to a Xiaomi Redmi Note 10; is that the correct phone you have? Because it's a completely different phone than the Xiaomi Mi Note 10, so it's important to know the difference.
Anyway, assuming you've tried booting the phone in Safe Mode and you're still seeing the same problem, that tends to indicate a hardware issue. I'm not sure if this is a translation issue or not, but I'm taking your reference to the "user Interface" to mean the touch screen. The issues you're seeing are usually indicative of a failing digitizer, and if that's the case, the only fix is to replace the screen assembly, since the digitizer, or touch screen, is bonded to the display.
On your phone the recommended method is to purchase the display already attached to the midframe; replacement then becomes a process of removing the phone's internal components and transferring them to the new screen+frame assembly. This guide shows you how to make that repair.
Complete Screen Repair (Screen + Frame) Redmi Note 10 - Free Guide - SOSav.fr
Since you didn't give us much information I've had to make assumptions so please let me know if anything I've surmised is incorrect.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
hasan dur zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 34
