Ga door naar hoofdinhoud
De Lenovo ThinkPad X380 Yoga is een 2-in-1-laptop die in 2018 door Lenovo werd uitgebracht als onderdeel van de ThinkPad X-serie.
Internal Microphone does not record sound
Hello iFixit community,
I am facing an annoying issue with my Lenovo X380 Yoga running Windows 11 (26H2):
It does not record sound using the internal microphone.
I tried every imaginable software fix:
  • the device is correctly detected and does not show any errors
  • it is running on the newest Conexant driver (version 8.66.89.51), but I also tried to run it using the native Windows drivers
  • it is unmuted with the Fn + F4 hotkey combination
  • the Level is at 100 % and Boost at +12.0 dB
  • Exclusive Mode and Signal Enhancements are disabled
  • access via the privacy settings of Windows is enabled for all apps
Since external microphones were working (both connected via Bluetooth or headphone jack), I considered a hardware fault. But even replacement of the microphone / camera card in the top of the screen did not help. I also checked the connection to the system board, but it seems fine.
When I got the laptop as a refurbished device, I switched the keyboard, but I'm pretty certain that the microphone was still working after that. Sadly I cannot say, when this issue started ... it was definitely some time (a year or two) ago, but didn't bother me too much.
Any ideas what else could be wrong with my system?
Every help or suggestion is highly appreciated!
Michael
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
the cable that connects it or the port may be the issue that or its just windows if you have the time then reinstalling windows may fix it if not that im not too sure what the cause could be other then a cable fault or cable connector fault
Was dit antwoord nuttig?
1 Opmerking:
also to add on you can check if its enabled in your bios when you turn your laptop on mash f1 and f2 and you should be sent there then go to security > i/o port access > then look for your mic and try to enable it also this might not be right for your laptop as bios navgation can differ so you would need someone who has a thinkpad with the same bios navigation or wouldjust need to find it yourself
door
Voeg je antwoord toe
michaelhuepkes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 54
Altijd: 54
