a record power not working
uf i press a red rec button on a pilot it works but if i press it on camera it doesnt
Is dit een goede vraag?
1 Opmerking:
Hi!
Could you provide some more information, your question is a little hard to understand.
What symptoms do you have, what expected symptoms do you not have? What symptoms do you have of things working and what symptoms do you have of things not working? Does your camera make any noise? Do you have a cassette in the camera? Does any display show anything? Are you running on battery or the power adapter, can you check their voltages?
What is the "pilot", and what "works" with that compared to pressing the record button on the camera?
Do you get any error codes (on the small side display)? Can you enter service mode and get access to any error codes (refer to page 6 in the service manual)?
With some more information we will be better equipped to guide you further in your repair journey.
Cheers
door Deel
Voeg een opmerking toe
