Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de 13-inch MacBook Air uitgebracht in maart 2025, met M4-chips.
MacBook clicking and cracking
I recently cleaned out my macbook air m4 keyboard with my pc blower but now its making clicking and cracking sounds everywehre whether i open it or close it or press anywhere i treat it like a gem and never damage it. i need help please.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
If it started right after using the blower, I’d stop using it for now. A PC blower can be strong enough to shift something slightly inside the hinge or chassis.
Try opening and closing it slowly and listen for exactly where the crack is coming from. Also check that the bottom case screws are tight and the case isn’t lifting anywhere. If the sound happens even when you just press the palm rest or bottom case, I’d get it checked rather than keep using the blower.
Was dit antwoord nuttig?
2 opmerkingen:
Im thinking of opening up the bottom case and cleaning it out to see if that fixes the issue
door
@shayanashayeri I’d be careful opening it just to clean more. Since the noise started after the blower, I’d inspect the hinge and bottom case for anything loose first rather than blowing more air inside.
door
Voeg je antwoord toe
Shayan Ashayeri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 55
