Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Why is the touch screen not responding?
The phone touch screen dosn't respond but the display work perfectly. I replaced the display but the same issue is persisting. who ever had the phone before me had done something because a screw is missing. ive also tried to made sure the touch screen cable was connected correctly.
Is dit een goede vraag?
Score -1
1 Opmerking
are you positive you didnt tear the ribbon cable when sliding it threw the slot in the metal frame
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There is a good chance the device suffered water damage. I would clean the digitizer connector on the logic board with rubbing alcohol let it dry completely and try again.
Was dit antwoord nuttig?
Voeg je antwoord toe
xmoonxboyx92 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,334
