BR151 Stuck in Docking Loop
When you turn the unit on, and tell it to go home, it will find the base and align with it, center up, go up the ramp, then bump against the back wall of the charging base to only turn around and do it all over again. I have noticed that just as it contacts the back wall of the charging base, the plug light on top of the unit will go from green to red for just a second, then back to green. It will do this dance indefinitely. I wondered if the battery could be bad, but they ain't cheap and I don't want to buy a new one without knowing if this will solve the problem. Contacts were cleaned. Censors cleaned. Battery was pulled from unit for 30+ minutes. Anybody solved this problem?
Edited to add: I checked the voltage on the docking station and it is getting voltage. The feet on the docking station are springy so they are not stuck. Everything has been cleaned with rubbing alcohol.
Edited again 8-24-2026:
Changed the battery out, but the behavior persists. Suspect it is probably the charging board. Firmware update requires installing an app that wants far too much information for the purpose it fills. No way am I going to turn loose a robot from Shenzhen, China on my WiFi network that is all ready having issues with a ton of personal info. I don't see any other external ports to plug the robot in via usb either. Will put this in the junk pile. Maybe some other parts will find their way here someday and I can cannibalize those pieces into one working machine.
Is dit een goede vraag?
Voeg een opmerking toe
