LCD only one warking
Only 1warking
Is dit een goede vraag?
If one of the screens inside your Meta Quest 3 is completely black while the other works fine, you are dealing with either a software glitch or a disconnected/damaged internal display hardware component.
A standard restart might not clear a stuck display driver. A hard reboot forces the headset to re-initialize both LCD panels.
If the proximity sensor is partially blocked, it can cause erratic screen behavior or single-eye blackouts.
If the issue is caused by a corrupted firmware update, a factory reset is the final software troubleshooting step. Note: Ensure your cloud backups are turned on in the Meta Horizon mobile app first so you do not lose your save data.
If the screen remains black after a factory reset, the ribbon cable connecting that specific LCD to the motherboard has either wiggled loose or the panel itself is physically damaged from a drop.
If your device is still under warranty, do not attempt to open it yourself. Go to the Official Meta Support Center to open a claim and request a replacement headset.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 42
