Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en demontage-informatie voor de MacBook Pro 16" uitgebracht in november 2019. Model A2141, EMC 3347.
Leftmost 512 pixels not displaying
I got this machine cheapish as the original display was smashed. The full image could be seen though. I had a spare here and it works fine except the leftmost 512 pixels which is very telling. That’s exactly 1/6 of the panel. There’s no physical damage to the display but I have noticed the lugs holding the metal covers over the ribbons down on the tcon have failed only on the innermost lugs. I suspect it’s been badly flexed at some point. My question is, could there be a tcon issue here? It feels more like that than a damaged lcd or flex gate. Never seen a flex gate lcd like this.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
The LCD panels ribbon cables is likely the issue, either they are damaged or the connection to the connection to the T-CON board. Does it look like someone tried popping off the LCD panel? Can you post some pics of the areas suspected of damage?
Was dit antwoord nuttig?
Voeg je antwoord toe
Joel Whybrow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 97
