Ga door naar hoofdinhoud
Why does it start and turn off
I started it with two fully charged batteries. It started fine and started flashing yellow and quit. The connections look clean with no obvious problems. It ran for several minutes one time, but mostly just seconds.
Is dit een goede vraag?
1 Opmerking:
Battery lifespan is between 3-5 years. One hint of battery wear would be shortened mowing time. With batteries removed, blades and housing cleaned, does the blade turn freely?
door
Voeg een opmerking toe
1 Antwoord
Ego battery has a hard reset. Press the red circle of death 3x's, and on the 3rd x, press and hold from 7-10 seconds if that doesn't work drop the battery about 12 inches away from the floor and charge again . If the cells are still alive it should show the green go light.
Was dit antwoord nuttig?
Voeg je antwoord toe
Lori Kilian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 94
