Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
20 Vragen Bekijk alle
iPhone 4s replacement screen white around the edges
I replaced my iPhone 4S screen and when I restarted it everything looked ok. After a short while however the new screen started displaying a milky white glow along the edges. I've reopened it and checked the connectors but no luck. I'm also suspecting that it's spreading. The digitizer works fine.
Any ideas what may cause this and how to fix it?
Update: after letting it rest overnight the screen looked fine first thing in the morning, however the white 'halo' reappeared shortly after. Heatsink issue?
Is dit een goede vraag?
Score 7
2 opmerkingen
Hi Tolga,
Many thanks for your answer. I think I have exactly the same issue as there's a gap between the frame and the screen on the left side on my phone too. will chase a refund.
Daniel
door
I had this problem with a customer's iPhone 4s after I attempted to modify a CDMA screen to fit. I used a dremel to cut off one of the tin notches and I think the vibration from the dremel damaged the LCD. I did the same thing to yet another CDMA screen--so managed to trash two of these units, in the same day, with the same white halo effect. Needless to say, I no longer try to convert CDMA screens to fit 4S screens.
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
Hi,
today I had the same issue with an iPhone 4S!
In my situation it was caused due to a bad quality of the replacement digitizer (incl. LCD). When I looked at the borders of the Digitizer, the left side of the black frame border was a little bit higher than the other side.
Due to this quality fault the LCD gets pressure from bottom and it causes white ghost effects on the outlines.
Will return it and order another one from another shop.
Good luck!
Best regards,
Tolga
Was dit antwoord nuttig?
Score 1
I did my repair. Tested it in the middle and it worked fine. Then when I got all done with it there was a white border. This was for a customer so as you can imagine VERY annoying. I have to get a new screen. Also it might have happened because I put in a screw under the motherboard instead of over it and it could have hit the LCD and caused it to white border around the edges.
Score 1
1 Opmerking:
I know that very well. Due to these quality differences I never order an amount of parts in stock. If you keep them for a long time and see the faults at a repair process for a customer , it's too late to send the item back. It's always better to order the parts you need for the current customers phone, when you need them.
door
My phone developed this white halo randomly: I had not just replaced it or done anything with the screen. It has spread rapidly all of today. When the image on the screen is black (such as when looking at a dark picture) six circles are noticeable.
Score 1
1 Opmerking:
This is EXACTLY what happened to me today, six circles visible on dark images and all! I too have never tried to fix this phone however, my hubby bought this off eBay, so we really don't know the history. However, it has worked fine for the last 10 months or so that we've had it. Anyone ever find out why? Or a fix??
door
Hello,
I ordered 5 x iPhone 4s digitizers (inc LCD)
But all of them have this problem: on the sides from the LCD there is white. What can I do?
On the original(broken) digitizer there is black tape behind the LCD. Make this the different?
Please help !!
Any solutions, couse china not give warranty easy...
I just replaced an lcd and after about 30 min it developed this halo. I haven't had a chance to fix it, but I think it was because I didn't remove the blue plastic film on the back of the lcd. Not having enough clearance, the plastic presses against the lcd and causes discoloration. Hopefully I can fix this issue tomorrow.
Why does it happen randomly? Sometimes I can restart and it's fine, some times a foggy halo but I can see the screen, and sometimes just black or a faint white circle. Mine worked great for four days and then this started happening.
1 Opmerking:
I need to figure this out quick - just sold the phone on eBay!
door
But its also possible that you have some dust or remains of old LCD between new lcd and the frame.
Yeah, I too have this problem.. The thing is, I would test the replacement screens before installing by hooking up the digitizer and lcd ribbons without dissembling the entire phone.. and the white halo still shows up after 30mins or so.. Leading me to believe it may be the connectors or something thats causing this.
Voeg je antwoord toe
Daniel Hansson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 41,726
