Ga door naar hoofdinhoud
Dit was Mahindra's eerste wereldwijde SUV gebouwd op een modern monocoque-chassis in plaats van een traditionele ladder-omlijsting. De auto werd voornamelijk aangeboden met een 2.2L mHawk turbodieselmotor, hoewel een 2.2L benzinemotor en een 1.99L dieselmotor ook verkrijgbaar waren.
Why there is no injection
Not starting due to fuel injection
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If your Mahindra XUV500 is not starting and you've determined there is "no injection" (meaning fuel isn't reaching the cylinders), the issue usually lies in the Common Rail Direct Injection (CRDe) system’s ability to build or sense pressure.
The ECU will not signal the injectors to open unless it sees a specific minimum pressure in the fuel rail. Here are the most likely reasons for a "no injection" state:
1. High-Pressure Pump or Fuel Metering Unit (FMU)
The high-pressure pump (FIP) is responsible for pushing diesel into the rail at massive pressures.
  • The Metering Unit: There is an electronic valve on the pump called the Fuel Metering Unit. If this valve fails or its wiring is damaged, the pump won't send fuel to the rail, resulting in zero injection.
  • Mechanical Failure: If the pump's internal drive has failed, it won't generate the pressure required for the ECU to "fire" the injectors.
2. Rail Pressure Sensor (The "Gatekeeper")
The ECU relies on the Rail Pressure Sensor to know if there is enough fuel to start.
  • If this sensor is faulty or the connector is loose, the ECU might think there is "zero" pressure (even if there is fuel) and will refuse to trigger the injectors as a safety measure.
  • Testing Tip: A mechanic can check the "Live Data" via an OBD scanner to see if the rail pressure reaches the required threshold (usually around 250–300 bar) during cranking.
3. Air in the System (Losing Prime)
The XUV500 is sensitive to air bubbles in the fuel lines.
  • If you recently changed the fuel filter or ran out of diesel, air might be trapped.
  • The Fix: Use the manual primer bulb (located near the fuel filter in the engine bay) to pump fuel until it becomes rock hard. If the car starts after manual pumping, you likely have a minor air leak in a fuel hose or a faulty non-return valve.
4. Crankshaft Position Sensor (CKP)
The ECU needs to know exactly where the engine is in its rotation to timed the injection.
  • If the Crank Sensor fails, the ECU doesn't know when to spray fuel, so it simply sends no signal to the injectors.
  • Observation: If your tachometer (RPM needle) doesn't move at all while you are cranking the engine, the Crank Sensor is a prime suspect.
Was dit antwoord nuttig?
Voeg je antwoord toe
sankar chakma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 208
