replacement automatic voltage regulator
I'm resurrecting an old Powermate 5000 Model PC0545305.01 with an obsolete & malfunctioning AVR (ICM AB3101-240). ICM weren't any help. This units AVR specs apparently has 240 VAC sensing and 25 VDC output to the brushes. I connected two 12 VDC batteries to the brushes to confirm proper output VAC. Can anyone identify a source for an AVR with the necessary specs?
Is dit een goede vraag?
1 Opmerking:
Also a generic question: is the ac from the sensing coil and the excitation winding in phase with each other? It appears that both excitation and sensing voltage is 240 vac.
door Deel
Voeg een opmerking toe
