Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
helpppp! touch screen not working after screen repair.
hi i bought a diy digitizer kit from icracked and the screen is working perfectly picture wise but it wont let me use the touch screen i cant slide to unlock or anything what do i dooo??? please help :(
Is dit een goede vraag?
Score 1
2 opmerkingen
please someone answer... i cant even call anyone to help...
door
thank you so much for your answer still cant get it to work but thanks.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The digitizer is faulty or not connected to the Logic Board perfectly. Turn iPhone 3GS OFF, carefully open, and reconnect Flex Cable #2. Make sure #1 did not come loose before you close it back up. If still no touch function, then the Digitizer with the Front Glass is faulty.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ashley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 817
